Pytanie do naszych specjalistow.
Silnik benzynowy, ale chodzi o olej do automatu ZF 4HP18FLA
midparts zaleca taki: RAVENOL Automatik-Getriebeöl ATF 5/4 HP Fluid
Co oprocz niego mozna wlac, podobno to zamienny olej z normami VW/Audi G 052 162 A1; G 052 162 A2; G 052 162 A6; VW TL 52 162.
Chodzi o zwykly 4 biegowy automat, nie zaden tip ani multi. Skrzynia z Alfy, PSA, VAGa
Automatic Transmission Fluid (ATF) according to lubricant classes 11A / 11B
=> Refer to the following pages for approved commercial products
or
Automatic Transmission Fluid (ATF) based on mineral base fluids according to
former Dexron-II / Dexron-III specification by General Motors.
=> without listing
szczegóły w pliku, do skrzyni masz szeroki wybór, ten syntetyczny Ravenol jest do nowszych typów, nie nadaje się.
Najlepszy będzie któryś z tych:
ADDINOL LUBE OIL GMBH, LEUNA/D ADDINOL ATF D III
AGIP SCHMIERTECHNIK GMBH, WÜRZBURG/D AGIP DEXRON III
AMALIE PETROQUIMICA, SL, MADRID/E AMALIE ATF DEXRON III
ARAL AG, BOCHUM/D ARAL GETRIEBEÖL ATF LD
BP INTERNATIONAL, PANGBOURNE, READING/GB BP AUTRAN LTF
CASTROL INTERNATIONAL, PANGBOURNE READING/GB CASTROL TRANSMAX Z
DEUTSCHE PENTOSIN WERKE GMBH, WEDEL/D PENTOSIN ATF 1
DEUTSCHE PENTOSIN WERKE GMBH, WEDEL/D PENTOSIN ATF TYP 2 D
ENI S.P.A. REFINING & MARKETING DIVISION, ROME/I AGIP DEXRON III
EXXON MOBIL CORPORATION, FAIRFAX, VIRGINIA/USA ESSO ATF D 21065
EXXON MOBIL CORPORATION, FAIRFAX, VIRGINIA/USA MOBIL ATF D 21065
EXXON MOBIL CORPORATION, FAIRFAX, VIRGINIA/USA MOBIL ATF LT 71141
KOMPRESSOL-OEL VERKAUFS GMBH, KÖLN/D KOMPRESSOL-DEXRON SYNTH LTF
KUWAIT PETROLEUM R&T B.V., EUROPOORT RT/NL Q8 AUTO 15
MORRIS LUBRICANTS, SHREWSBURY/GB LIQUIMATIC SUPER ATF
ORLEN OIL SP. Z O.O., KRAKOW/PL HIPOL ATF III
PANOLIN AG, MADETSWIL/CH PANOLIN ATF DEXRON III
REPSOL YPF LUBRICANTES Y ESPECIALIDADES, MADRID/E REPSOL ATF 3
TOTAL LUBRIFIANTS S.A., PARIS/F FINAMATIC HP
TOTAL LUBRIFIANTS S.A., PARIS/F TOTAL FLUIDE AT 42
YACCO, ST PIERRE LES ELBEUF/F YACCO ATF III
ZF GETRIEBE FRIEDRICHSHAFEN AG, SAARBRÜCKEN/D ZF LIFEGUARDFLUID5
. Ja już prawie kupiłem, ale odpuściłem z tego powodu.
